CCleaner and chrome frame issue
Hello,
Not a bug per-se, but just a quick courtesy note & a FYI concerning something I ran into with CCleaner and "Google Chrome Frame"
I am trying out a program called Plex. Part of the installation recommends to install "Google Chrome Frame".
http://www.plexapp.c...ownload-new.php
This portion recommends the chrome frame install:
For optimal performance and compatibility with Plex Media Manager, we recommend Google Chrome, Safari, FireFox, or IE9 with Google Chrome Frame.
http://code.google.c...me/chromeframe/
When I ran CCleaner today I got a pop-up saying I needed to close Google Chrome.
I did not have any web browsers open, so I looked at my running processes.
I noticed ("chrome_frame_helper.exe" --startup") was running.
After killing the process I was able to run CCleaner as normal.
The "Chrome_Frame_Helper" is listed within a few start-up location within my system
HKCU\Software\Microsoft\Windows\CurrentVersion\Run ChromeFrameHelper chrome_frame_helper.exe
HKCU\SOFTWARE\Classes\Protocols\Handler gcf npchrome_frame.dll
So this "chrome_frame_helper" is always going to run at startup, if I leave this helper installed
As mentioned, I did not have any web browsers open.
Thank you for having and maintaining such a fine set of tools.
Chrome frame tends to run in the background and is indeed a instance of chrome and thus is an open browser. Kill the process before cleaning chrome items via ccleaner
