I have noiced that the "last scan " repoted by AVG is being deleted by CCleaner after running CCleaner.
In the cleaning section, under applications do you have an item for AVG that is checked? Was this the normal behavior in the past to remove the last scan result? Im not an AVG user
Is the the name of the last scan result file always different? If not you can add an exclusion.
