CCleaner and an SSD Drive (safe?)
I have trying to find information regarding using ccleaner with an ssd drive. I have read many threads on different forums all of which seem to give different information. I know you should not defrag an ssd drive My question, is it ok to use ccleaner on an ssd drive? If so, can you use the registry cleaner in ccleaner?
Yes it's fine. Just don't wipe freespace or use any secure overwrite setting
Hi and thanks for your reply. I was aware not to use the drive wiper but is it ok to use the registry cleaner?
It is as safe to use registry cleaner on SSD as it is on a hard drive
Many thanks for your help.
