CCleaner and all others have a strange text style
Hello,
I'm a Windows Seven SP1 64bit user that has noticed a strange graphic bug on all Piriform softwares.
Basically the text is too big and bold, a screen is attached.
What can I do?
Have you installed IE9?
That seems to be a common complaint of IE9 causing
bold/large and/or ClearType problems. Both in
programs and websites.
You might browse Microsoft Answers/Internet Explorer
forum if the solution isn't found here.
I have IE8 installed and the problem is actually there since 6 months
Some programs are affected by IE text size and fonts settings, although I'm not able to get CCleaner to show big bold fonts changing it.
Make a System Restore Point before changing the IE settings, that way you have an easy way to undo anything should the need arise:
* You could look into this area of IE, and make sure it's set to Medium which is the default setting, screenshot:
* Also the fonts you have IE configured to use can possibly mess with some programs, go into Internet Options to access them, screenshot:
Other than that it could be how you have your Windows Theme font settings configured. I must say I wish CCleaner had the option built in to change the font size it uses which is now too small for my eyes.
