The default ADVANCED OPTIONS setting is to delete ONLY those temp windows files OLDER than 48 hours!
Why not delete ALL of the temp files on demand -- when you run Ccleaner?
There must be a good reason to keep them for at least 48 hours? No?
Louis
Louis
Louis
I note that the User's Guide gives the following [paraphrased] explanation for why the files are kept for 48 hours: In case some of the temp files are currently being used.
That makes some sense, but what temp files would you want to keep for 48 hours?! Also, it would seem that keeping temp files that long COULD be a security issue.
Just uncheck the box to delete everything???
well i think that it should have a box opt to pick from eather 06 12 18 24 30 36 40 or 46
