CCleaner 7 will not run
Installed (and deleted) CCleaner 3 times on win 11 box. Even ran Repair. Nothing will get it to run. What’s up?
It could be various things, you will need to describe better what you do and what happens.
One question though - Are you running an Antivirus/Security app other than Windows Defender?
Some AV’s have problems with new software versions and will block them from running until the AV’s database gets updated to recognise them.
If that is happening then you can (temporarily?) make CCleaner 7 an ‘Allow’ in the AV.
Hi @ErnieP,
From what I’ve read, I’ll stick with v6.9.
