On gathering and analyzing files stuck at 93% when using Health Check option.
Never finishes. This is with CCleaner 7.
End Task on it and try again?
At 93% I suspect that it is sticking on a Software update or Driver update scan.
That could be an internet problem, they usually get sorted out fairly quickly, try again tomorrow.
If it continues sticking then it might be your AV/Firewalls blocking CCleaner from connecting to something.
It finally did finish. I just let it run on the computer. Walked away and maybe an hour or two to finish?
Well hopefully that was just a bad connection on the web getting fixed after an hour or so,
Hopefully just one off and it won’t take that long next time.
Hi @jcurbaniak
Are you still experiencing this issue?
If so, please contact our support team via the Contact Us page on our Help Centre using the same email address you used to make your purchase. Once you have clicked Submit, please click the Start Chat button to give details to an agent so we can investigate this further.
