Ccleaner 7.0 Autostart issues
Hello,
I had some problems with the autostart manager in previous version of Ccleaner. It blocked some scripts marking them off the autostart list, even if I set them back on. I’ve managed to work around it, however in the newest version (7.0) the autostart settings are severely limited and I cannot access the data that I used to fix the issue.
The script in question was responsible for the PACE licensing program, which is necessary for Avid Media Composer to work correctly. I am not able to launch it since the update.
Those anyone have similar issues, or know a way to install a previous version of Ccleaner?
Thank you for your help.
See:
