When I run the latest CCleaner installation as an Admin on Windows 10 19042.572 it will install it quickly but without any windows which asks about Install or Customize. After the installation there is no entry in start menu I'm also not able to uninstall CCleaner....
@nukecad Thank you for pointing this out as I had failed to acknowledge that and I appreciate you for bringing it to my attention!
@Marcello Our software does not support 'beta' or testing versions of operating systems, such as the Windows Insider Preview versions of Windows 10, therefore it may not be abnormal for you to experience these types of issues with CCleaner on this version of the OS.
@MeganCCleanerHaving noted that build is insider - 20H2 is supposedly very close to full release (next couple of weeks?) and any issue with that insider build may make it into the RTM.
So at this late stage it is probably worth looking at in case it does make the stable build.
