The bug with the installer screen not showing correctly is likely to do with some remote content not being retrieved. This could be down to a rule in your firewall, blocking some but not all communications. Please double-check to see if anything from CCleaner or our parent company, Avast, is being blocked.
Thanks for the information about 'Sciter' in Health Check.
With Win 7 installation; we have numerous forum posts from Win 7 users for whom the Standard installer won't work but the Slim will.
If it looks like a duck and quacks ....
(As for the comment about the graphics in the installers, I am going on what has been said previously about the installer graphics by a staff member, maybe even yourself?
I'll see if I can find it again, it's a while ago now, I think it was around v5.40?)
1 hour ago, Stephen CCleaner said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> Please double-check to see if anything from CCleaner or our parent company, Avast, is being blocked. </p> </div>
Blocking via HOSTS file and/or Firewall causes CCleaner v5.66 (the version I tested) to take a very long time to launch, at least 10 seconds.
8 hours ago, Stephen CCleaner said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> As an aside, the main CCleaner installer should run correctly on Windows 7 and I see no indication of any widespread malfunction here </p> </div>
... although, if I may add, there were some specific instances of people claiming to have Windows 7 issues which actually turned out to be attempting to install or run CCleaner in Windows XP emulation mode.
