CCleaner 5.45.6611 Monitoring keeps turning on
This is a bug report for version 5.45.6611. When you disable the monitoring it does not stay. When you restart the computer CCleaner starts up automatically and the monitoring is checked again. Please fix this bug that prevents you from disabling the monitoring, I don't want CCleaner running in the background or starting up automatically.
Found a great workaround to this issue that doesn't require modifying task scheduler or deleting any files. Install version 5.44.6575. That version works great.
[Link removed by moderator old versions can be found at https://filehippo.com/download_ccleaner/history ]
Please don't host your own downloads (or go to sketchy self owned links) of ccleaner; not only is it dangerous, it breaks the license. I've edited your post to the correct location for historical installers.
7 minutes ago, Nergal said:
That works as well, however Negal, that site does not have version 5.44 which if someone is looking for that version they will have to go elsewhere.
OT yes they were looking in the missing 5.44 but moderators never heard back on that, probably because .45 blewup so badly on them.
