CCleaner 5.16.5551 NO registery issues found?
I installed the latest update and now when I scan for issues, nothing comes up. This has never happened before. I always have multiple issues whenever I scan the registry. Am I missing something?? I've been using CCleaner for several years and never had this happen, so I am concerned that something is amiss.
Well, never mind. I went ahead and scanned again and now it found 59 issues. Strange...
Very strange,
What the h*** are you doing to mess up your registry that much all the time?
Its not usual to see any registry issues unless you have recently uninstalled something.
Unless you are just seeing the issues and not fixing them?
You may want to visit one of the free malware cleanup help sites to check out that you have not been infected.
Here is one that gives one-to-one help for free ( there are others).
https://forums.malwarebytes.org/topic/9573-im-infected-what-do-i-do-now/
Here is another- take your choice; but only pick one, and stay with that one until the helper gives you the all clear.
http://www.techie7.com/threads/read-this-first-important-instructions-updated-4-28-2013.68933/
Could be something auto re-registering but that many keys sounds alarming.
I had the same situation yesterday on a win 7 laptop. CCleaner ver 5.16.5551 was installed over top of an older version.
First look at the Applications tab showed a blank panel. Second look a couple of minutes later was normal.
First registry scan, nothing found. Second scan found many issues and fixed them.
Scan was probably correct, the laptop had been used pretty hard, software-wise.
