valcan
August 29, 2011, 9:24pm
1
Hello all,
I updated my old CCleaner version with the latest one v. 3.10.1525.
Now I'm receiving by my AVG Resident Shield following alert advice:
"File Name: c:\Programmi\CCleaner\CCleaner.exe"
"Text: Impossible to scan the file. May be file structure is unvalid (Address 6aebd0f6)"
"Text: found on file opening"
Screenshot attached.
I neveR had problems with older CCleaner versionS, my AVG version is 9.0.901 and DB virus is 271.1.1/3865
updated today.
My system is windows 2000 professional Service Pack 4 Update one.
Is anybody that experienced this situation and that can give me an answer?
Thanks on advance.
Regards,
Mario - Rome/Italy
Nergal
August 29, 2011, 9:54pm
2
This seems to be a false positve in your Anti-Virus. As long as you got CCLeaner from either this site or from File Hippo (these are the ONLY two official sources for piriform softwares) than you just need to let AVG know about the false postive and they should fix it for the next virus definitions.
valcan
August 30, 2011, 10:18am
3
Nergal,
thank you for prompt reply, I agree with you I suppose this an AVG false positive as I downloaded
CCleaner from this site. I wrote a post into AVG forum some days ago and I'm waiting for a reply from them too.
I will keep you informed in case.
Bye,
Mario
Most antivirus' either have a built in "upload tool", or such said tool built into their websites for reporting a false positive.
updated today.
Regards,
Mario - Rome/Italy
Mario, have you tried the newer 2011 release of AVG (Version 10)?
It may help you. I'd check to see if it runs on W2k first, but you can get it on Filehippo.
According to the Softpedia.com download page it does NOT support Windows 2000!
OS: Windows XP / Vista / XP X64 / Vista64 / 7 / 7 x64
