CCleaner 3.02.1343 and Adobe Acrobat X Pro
Hello all, the last version of CCleaner 3.02.1343 It has no support for adobe acrobat pro x why?
I think you're incorrect, as according to winapp.ini (the file embedded in CCleaner):
[Adobe Reader 10.0]
ID=2176
LangSecRef=3021
Detect=HKCU\Software\Adobe\Acrobat Reader\10.0\AVGeneral
Default=True
RegKey1=HKCU\Software\Adobe\Acrobat Reader\10.0\AVGeneral\cRecentFiles
FileKey1=%LocalAppData%\Adobe\Acrobat\10.0\Cache\Search|*.*
FileKey2=%LocalLowAppData%\Adobe\Acrobat\10.0\Search|*.*
unless acrobat and reader are two different programs, I personally was always under the impression they were the same.
I believe the poster refers to the non-reader acrobat
http://www.adobe.com/products/acrobatpro.html
however I can only aid in the cleaning of acrobat standard 9.x as that is all I have
in the current winapp2.ini file is
[Adobe Acrobat Cache*]
LangSecRef=3021
DetectFile=%LocalAppData%\Adobe\Acrobat
Default=False
FileKey1=%LocalAppData%\Adobe\Acrobat|*.idx|RECURSE
has anything change in acrobat x ?
what other items would you like to see cleaned in it?
we will need (from you) a detectable registry entry or a file or folder which will tell CCleaner that you have A.P.X. installed and all of the locations of the files and/or registry keys you want removed
here is an example for Adobe Acrobat 9.0
[Adobe Acrobat 9.0 Most recent Files]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Acrobat\9.0
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Acrobat\9.0\AVGeneral\cRecentFiles
