Ccleaner 2.28 NOT slim
Hi,
i have downloaded the last 2.28.1091 release of Ccleaner.
The main webpage is changed and i cannot find the 'slim' version, as usual.
Why ?
Thank you very much for your fantastic software.
Regards.
Slim build ... http://www.piriform.com/ccleaner/builds
Hi,
Why ?
Regards.
It's there, but it's not easy to find.
First go to the main download page: http://www.piriform.com/ccleaner/download
Scroll down and click as shown:
That takes you to the same place identified in marmite's response.
It's pretty poor that's it's so obfuscated :(
It's always been in the same place
i had the same problem finding the other builds too.
Ah so it's always been tucked away then! ;)
Doesn't help new users, in particular.
Making the other builds obvious would remove one of Piriform's only sources of income - the Yahoo toolbar.
But new users wouldn't be downloading it:
Builds below are for system admins and advanced users
But new users wouldn't be downloading it: ;)
Eh?! An inexperienced user maybe. But as a new user to CCleaner why on earth wouldn't an experienced computer user want to have the choice of installing a slim build, a U3 build or a portable build?
A new user (to CCleaner) and an advanced (PC) user can be synonymous! Maybe the test of an advanced user is finding the link ;)
