I'll try the new version and I love it. As there's no dependency, I can launch it on severals computers without installed it.
Here's the bug :
When CCleaner 2 cleans the hotfix uninstallers, it deletes the files but not the folders. After the cleaning, I have $NtUninstallKBXXXXXX$ folders and the spuninst subfolder.
Thanks you're right, this is a bug, will be fixed in the next beta.
This doesn't happen only with hotfix uninstallers, also with folders in the temp dir (usually, c:\documents and settings\<user name>\local settings\temp)
