I love this app. You guys are the greatest and I am not complaining at all....I have been using IE7 since it was been released to beta testers (I am a legit tester) and I am still experiencing the same problem I had with previous versions. This could be my setup, so I am not stating this is in all cases:
I log into a few sites (lets use Google for example), and then install ccleaner 1.29.295 and below. I select to save the google cookies. IE is closed and I run ccleaner. I open IE7, and my cookie remains, all is well.
I reboot, with or without having ccleaner clean on startup, and my cookie is gone (but not really gone, I'll explain later). If I open ccleaner, go to cookies, it shows it is still there, and it is still marked to keep. This even occurs if the entire cookie open is unchecked.
Now, the wierd part. If I go to Documents and Settings, Admin (as I am logged in as), local settings, temporary internet files....the cookie is still there.
I have played some more, and if I don't mark any cookies to keep, they all are gone in that folder, so the keeping safe works, but again, not really since IE7 doesn't see it anymore. Also, if I uninstall ccleaner, all is normal again, and the cookies are picked up by IE7 on reboots and all. As soon as I install ccleaner, and reboot, IE7 no longer picks them up.
Any suggestions, thoughts, ideas? All my setups are default directorys and folders and such, so nothing is customized or unusual.
