Ccleanar Pro não limpa a lixeira
Boa noite. Adquiri o Ccleaner profissional, mas ele não limpa a lixeira mesmo ela estando marcada no menu de limpeza.
Quote
		<span class="VIiyi" jsaction="mouseup:BR6jm" jsname="jqKxS" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="pt" data-number-of-phrases="2" data-phrase-index="1" jsaction="agoMJf:PFBcW;usxOmf:aWLT7;jhKsnd:P7O7bd,F8DmGf;Q4AGo:Gm7gYd,qAKMYb;uFUCPb:pvnm0e,pfE8Hb,PFBcW;f56efd:dJXsye;EnoYf:KNzws,ZJsZZ,JgVSJc;zdMJQc:cCQNKb,ZJsZZ,zchEXc;Ytrrj:JJDvdc;tNR8yc:GeFvjb;oFN6Ye:hij5Wb;bmeZHc:iURhpf;Oxj3Xe:qAKMYb,yaf12d" jscontroller="Zl5N8" jsdata="uqLsIf;_;$12" jsmodel="SsMkhd" jsname="txFAF"><span class="Q4iAWc" jsaction="click:qtZ4nf,GFf3ac,tMZCfe; contextmenu:Nqw7Te,QP7LD; mouseout:Nqw7Te; mouseover:qtZ4nf,c2aHje" jsname="W297wb">I bought the professional CCleaner, but it doesn't clean the trash even though it is checked in the cleaning menu</span></span></span>
Is it set to only clean files that are more than 24 hours old?
If so it will not clear from the Recycle Bin any files that you have deleted today.
Ele está configurado para limpar apenas arquivos com mais de 24 horas?
Nesse caso, não limpará da Lixeira nenhum arquivo que você excluiu hoje.
