CCcleaner not working
new versions of cccleaner app cleaning dept is not working at all both cleaning tabs on the bottom are not lit
running a compaq computer with windows 7
working fine on win 8 on a accer note book
and a second compaq computer in house
also on the mac working fine
Plot Thickens
My problem started when i downloaded that CCleaner exstension thought i was being clever I never found it on my computer i think I have installed it. But do not know what it does
If you're using the winapp2.ini file or CCEnhancer remove both of them and then see if CCleaner works.
If CCleaner still doesn't work:
1. Uninstall CCleaner.
2. Restart Windows.
3. Reinstall CCleaner.
