Is there a difference between these 2? I have a cc pro subscription and have just updated to v7
Like all CCleaner versions for years v7 can be run as either Free or as Professional.
You can check which your v7 is currently by going to Settings > My Subscription.
If it isn’t curently activated as Professional then you enter a valid licence key to activate it.
Thanks, it’s all fine as you stated.
