CC kill autologin for Skype for Desktop
CC v5.63.7540 64 bit, using "Custom Clean" with Application "Skype for Desktop" disabled. So the bug is Skype is set to autologin on start (both start from reboot and start as windows menu launch), and after running CC "Custom Clean" then I close Skype for Desktop, then I start it again, and the auto user login to Skype failed. IF I didn't run CC "Custom Clean" then I can close Skype and start it (from menu orreboot ) and I will auto login no problems. Why does disabling the CC Custom Clean on Application tab for "Skype for Desktop" still does something that breaks my Skype auto user login?
Have you possibly enabled the "Network Passwords" option (Custom Clean > Windows > Windows Explorer)?
