CC crashes at "System Restore"
Is it just me?
As I open the System Restore TAB, my CCleaner crashes.
Latest version of course :)
Is it just me?
At the moment, yes.
System restore function in CC does not work at all on my PC (AMD3000 2Gb,WinXP SP3) The window opens but there are no restore points listed.
I sometimes connect to external (usb) Hard disks and usually turn off restore for them, so this may also be a factor.
Not very meaningful.
I hate such statements - so misleading.
Firstly, I CANNOT tell if you are complaining about the "Latest" version now available, so I do not know if any such problem still exists.
Secondly, you may have downloaded on the same day that a new version becomes available, in which case date identification is useless.
Today is just one of those days when I think I might update some software, and I like to check any user forum for any reported problems before I risk the same.
Because of the meaningless "Latest version of course", I was irritated by the extra searching to find it was probably version v2.21.940 released on 25/06/2009.
I do not intend to single out ishan_rulz for criticism,
I just wish to recommend for any-one who has a problem that a version number will always be meaningful,
and "Latest version" will ALWAYS BE WRONG after the next release.
Additional related comment / complaint to developers,
It would be useful if the change log showed the date of release for every version.
The changelog is naturally the first place I looked to see what was "latest" as at July 1st, and of course I was disappointed.
If anyone posted a fault before 25th June it would have referred to a previous version,
and I just cannot see any clue upon release dates for versions other than the last version.
Regards
Alan
