why are they still taking $$ for subscriptions but not fixing the problem?? thanks for stuffing up my comp ccleaner
As this thread is four years old the it’s unlikely that you have the same problem.
You may be getting a similar effect perhaps but CCleaner has changed a lot in those four years and the driver updater is differently programmed to what it was back then.
(Although I note that you don’t even say if you think it was the driver updater that glitched your machine).
As this thread is obviously about a four year old issue and not anything current I will close it to avoid confusion.
Please start a new thread, giving details of your Windows version, your CCleaner version, and exactly what it was that you did before you bluescreened.
If you explain what yout “several issues” are someone may be able to help (and may be able to work out just what happened).
