Hello there.
I was wondering if anyone can help me with this issue. My pc has been crash dumping,and i can't run many apps due to message: "runtime error abnormal program termination" on windows 7.
I was also wanting to know,if CC Cleaner can fix this problem in the registry?
Any advice on this will be greatly appreciated, Thank you.
The goal of CCleaner is to clean your machine of old registry entries it does not fix serious software problems although it may cure some minor ones.
First try running "chkdsk.exe /f" reboot and see if find any file system errors.
Next search Google for "microsoft redistributable" and download the C++ redistributable for 2005, 2008 and 2010.
If that still doesn't work try performing a System Restore and see if that helps.
Richard S.
