CC cleaner running a lot slower on my laptop
I just downloaded the latest free version, and it's a lot slower when I run the cleaner, just wondered if there was a fix for that or not yet... thanks. It used to take about a minute or less to clean the junk after I use Google and spend some time online, now it takes 5 minutes or more so yeah it's slow. Just saying.
can you tell us the exact version number you are using as there have been two recent releases within hours of each other.
