so i recently ran into a microsoft problem on my computer and they couldnt fix it nor could i so i was forced to reset my pc. After doing this i realized i didnt have my ccleaner serial key anymore bc it was on a notepad file on my pc and i lost everything ccleaner, defraggler, Recuva, and speccy is there anyway i can get these back i really need them to keep my pc clean.
keeping your PC clean is not lessened by running the Free version of CC as compared to the Pro version.
(yes, the Pro has extra monitoring, multi-user, support benefits, but the junk removal is the same)
you will have to raise a support ticket with Piriform to request your licensing info once you provide the necessary details.
send an email to support@piriform.com and an agent will be able to chase it up for you.
i understand its not lessened but i had the pro version and im currently having to use the trail thank you for your help hopefully i can get my ccleaner back
no worries and good luck.
BTW: the license key would have been emailed initially, no chance you have emails going back till then?
wait just saw this wouldnt this work??? http://www.piriform.com/support/license-lookup
it was like one year ago sooo lol i dont think so i get a lot of emails
anyway i can check for a certain email?
OMG I just used the license key tracker thing after i just asked for help and i got everything back...well i think let me install everything first
wow got it all back i feel retarded :\
hey, a win is a win.
Definitely a win for you iiSpaceGod
