Cant print after runnin cleaner
I have run the cleaner twice. First time I ran it I couldnt print, was recieving an error about the USB port(sorry cant recall the error) and had to reinstall the driver.
I ran the cleaner again the other day, tried to print and the same thing happend.
Anyone know what is going on, or why the cleaner would be affecting my printer?
Welcome grover
Can you give us more information such as operating system and Service Packs applied and the make and model of the printer.
Thank you for the warm welcome.
The printer is a dell AIO 922 ( dell is the one that suggested the CCleaner but could not figure out why I couldnt print.... they of course said it wasnt anything they did, sigh)
OS is Windows XP 5.1 Service Pack 2
Thanks for your help, has anyonelse had this problem?
Welcome grover
Please read:
http://forum.piriform.com/index.php?showtopic=17760
By the way Service Pack 3 has been out for 4 months now so it might be a good idea to update through IE by going to Tools then Windows Update then installing the updates.
On October 14th Microsoft probably will have a few more updates as it is Patch Tuesday.
