Cannot Partition after running Dfraggler
I have a problem with running the partition program of Windows 7 after I ran Defraggler.
The program will only shrink a drive down to the last bytes used on the drive. When I started that was at 135000 bytes. After running Defraggler it put one block of data at the end of the drive and now I only have 144 bytes that I can shrink.
Does anyone have any idea how to move that away from the end of the drive?
Thanks for your help.
What was put on the end of the drive? You can find out by clicking on the blocks in the drive map.
If you used the "Move Large Files" to end of drive option, then uncheck it, and defrag again, the data should get compacted to front.
Defrag freespace should move it.
Richard S.
