Hi, since a wile i get a popup saying that the program crashed( see the pic in attachment) . When i close this popup also the program is closing, and also trying to send a report i get a fail popup and then the program get close.
I uninstalled and reinstalled the program, the Licence is ok and till end of January 21 valid, and now i don´t know how i can solve the problem.
Looks like the error message may be legit.
<a href="https://www.tenforums.com/software-apps/27630-ccleaner-keeps-crashing-windows-10-a.html" ipsnoembed="true" rel="external nofollow" target="_blank">https://www.tenforums.com/software-apps/27630-ccleaner-keeps-crashing-windows-10-a.html</a>
Fair enough,
the linked post from trium also shows the same message.
(And checking about I can find a few other examples).
But it still looks very odd to me, and my points from above still stand.
Why have a countdown on an error message? Is it going to send the message after 5 minutes whether you click to send or not?
And why say "The Application CCleaner has quit unexpectedly" making it sound like the message has come from somewhere other than CCleaner itself?
Why not just "CCleaner has quit unexpectedly"?
I'm guessing that the problem that caused the error is related to Edge preloading/running in the background, that seems to be a common problem at the moment.
i remember me darkly in the past i have also such a message and i dont have enought time to send whatever (no internet at this time of 5 min)
I have also run into this same crashing issue as of probably January 4, 2020. Have tried uninstalling and reinstalling the software to no avail. It seems to work for a while and then begins crashing, usually on the analyze portion. I am using Windows 7 32 bit OS. Not sure if this matters or not. Have been using CCleaner now for almost a decade with no problems until recently. Also, thought I might have malware which might be causing this to crash but ran numerous scans with different programs and from what I can tell my system is clean but still getting crashes. I am also running CCleaner free edition version 5.63.7540.
Hope this helps. I suspect there is a bug in the program somewhere. Hopefully Piriform can fix it. There product is awesome.
i have tried cc v5.63 portable on two xps 32bit, one w7 32 bit - all good as it seems with easy and custom clean -only analyze - no app-crash-report in my case
Hi guys, tank´s a lot for all your posts and sorry if did not comment this till now.
I really don´t know if this could be relevant or not, but i find out that if i start the program and i start the cleaning at once, the program is running ok and i don´t get any "warning" message.
This Appen just if i open the program and i let that stay open for a wile without using.
It is a bit odd but at least I have a short solution.
Thank you all again and let´s see how is going to be.
This could be related to Bitdefender. We have previous reports about 32-bit OS users about Bitdefender causing errors in CCleaner, and have been recommending that if a user has Bitdefender, that they exclude CCleaner. If they don't have Bitdefender, then we will probably have to direct the user to support and investigate further.
