Can I use CCleaner's reg backup to restore my system
my system is stuck in safe mode. Try to boot up, gets a quick instaneous flash of a blue screen, then back to safe mode. All my icons are there, can access my files etc, but cannot get into normal xp mode.
I have been using ccleaner for some time, and it has made backups of my registry, even recently before this crash. Can I use ccleaner in safe mode and restore a registry to bring win xp to boot into normal mode again?
Larry
Larry the ccleaner backups you make are not of your total registry, just of the things that ccleaner fixes at the time.
The backsup which are kept in 'my documents' by default ,could be merged in safe mode without the need for using ccleaner. Just right-click and choose merge.
Does system restore not work?
Do you have a windows xp cd?
Also consider the fact that a virus or malware could cause this sort of problem, perhaps you could download and run some of the cleaning scans here and post in the spyware hell part of the forum with the logs.
http://forum.piriform.com/index.php?showtopic=20120
Are you able to use safe mode with networking as a choice?
If not perhaps a friend could help by downloading them for you.
I am in safe mode now. I do not have a xp cd, this laptop did not include one. But when it boots, it gives me the option of recovery console. I have one folder in the system vol information folder for restore files, dated 12-17-09, which I remember is a good configuration. I cannot access this thru safe mode. Any ideas?
Have you tried doing My Computer>right click on C Drive>Properties>Tools>Error Checking>Check Now. Tick both boxes, start, ok, then reboot.
If you right click My Computer>Properties>Advanced>Startup & Recovery>Settings>System Failure and take the tick out of 'automatically restart', this will allow you to read what the BSOD is saying and may give some clue as to the cause.
What about any virus/malware possibilities?
maybe you should deactivate the applications which are starting with windows automatic. Maybe one of this make the blue screen. when does the pc restart?
