can drive wiper fix problems?
my game used to run at 130 fps , now it runs in 40 fps , idk whats the problem but my laptop is suddenly slow in everything since last 1 week , i tried everything(no virus nothing) , i cant factory reset my laptop cause i dont have windows installation disk ,so is drive wiper safe and same as factory reset? ( i already backed up my files ) i dont want files in my laptop , and what are the 4 types of overwrite do ?
You cannot wipe your entire drive while you are still in it (if you catch my drift)
What operating system are you using?
Windows 7
Drive Wiper isn't going to fix such issues!
If you think your computer is possibly infected read item #10 in the forum rules which lists reputable trusted forums and sites that have free malware removal help.
