CCleaner is installed on drive D. It only cleans drive D. How can I get it to clean the C drive also. I haven't found a setting that lets you select drives.
Thanks for any help.
install it on C:
I did, but oddly enough it still only cleaned files on the D drive, nothing on the C drive. I don't have a "main" drive because I use the two drives interchangeably; some program files are on C while others are on D; so it would be nice if I could clean both.
Strange, I think that it should use %SYSTEMDRIVE% ...
