C Cleaner
when I run C Cleaner, it took away all my http addresses I typed in on my address bar in Internet explorer. If I uncheck recently typed urls will the addresses stay there. I visit this Http daily and don't want to have to type the address in every time.
Hello Valerie and welcom to the forum :)
Yes try unticking recently typed urls, this should solve your problem.
Can I also suggest Valerie that you have a read here, it should answer other questions you may have
http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
