c cleaner
ran registry cleaner backed up deleted files and back upfiles wont reinstall says error cannot find registryred ted newby
Welcome to the forums Ted :D
Go to my documents where the backups are stored, right click on one, and click merge.
That should work ;)
-aaron
If you happen to be using something like Windows 9x open the .reg backup created by CCleaner and make sure it starts with:
REGEDIT4
If it starts with something like "Windows Registry Editor Version 5.00" those won't merge on Win9x.
