C Cleaner Very Very slow
Hello
I have already reinstalled CCleaner 4 times, but it takes 30 min before CCleaner to show up , i have never had this problem before . I have the latest CCleaner.
Vista SP1 2.0Ghz 2GB Ram.
Could someone help me ? CCleaner always booted in 2seconds, but now ....
Thanks in advance.
Hello SleejR :)
If you go back to the previous version does this still happen? Previous versions can be downloaded from here
http://www.filehippo.com/download_ccleaner/
Where did you download from?
Have you installed any new software lately?
and last but not least, are all your virus/malware scans coming up clean?
Hello SleejR :)
Thank you for your reply,
Downloaded from filehippo :)
I will try the older version . No spyware or adaware/Virus i think no.
New software yes :), because i had to format my hard drive :(
thanks i will keep in touch
Hi SleejR,
Don't forget to go to MS Update and make sure you get all the updates for your PC.
http://update.microsoft.com/microsoftupdat...t.aspx?ln=en-us
Your CCleaner will run faster with the newer C++ programs.
Did you Reboot after installing CCleaner? If not, do so especially since you have a freshly reinstalled OS.
Best wishes,
:) davey
http://www.ccleanerbeginnersguide.com/
CCleaner Beginner's Guide.com Bookmark and save to Favorites
c++ programs, where can i get them ? you mean programming tools like borland c++ ?
Hi SleejR,
As long as you have installed all the MS updates you should have what you need for C++ programs.
CCleaner is written in C++.
If you updated but did not Reboot, then the older versions of some MS programs could still be in memory and problems could result.
:) davey
Are you still having problems with the latest version ?
What caused you to reformat your Hard Drive ?
Have you installed any other new software ?
If you are still having problems,please answer the following questions.
The following info will help others to come up with a solution.
These answers help to evaluate the problem.Provide as much information and detail as you can.
Just fill in the answers next to or below the questions?
Did you reboot after installing CCleaner before trying to run it?
Did you do any Registry issues fixing?
Do you continue to scan for issues until no more are found?
Did you do any software or hardware changes installs or uninstalls recently ?
Are you running with Administrator privileges.
CCleaner version ? What Language did you request at install,if any?
OS,edition ,32bit or 64bit and version ?
Browsers and ver.?
Security software and ver?
Other data you think might be relevant?
What did you do and then what happened?
Best wishes,
:) davey
The CCleaner Guide is your first source of information.
http://www.ccleanerbeginnersguide.com/ CCleaner Beginner's Guide.com
Bookmark & save to Favorites
Thanks for taking your time to make a report.:)
The older version did , because now it is back as fast as it used to be .
So thanks for your help !
Thanks for letting us know SleejR that you are back to normal CCleaner speed now , perhaps the next version will work for you.
