C Cleaner my short cut missing
I am using C Cleaner professional and all of a sudden it vanished where is it so I can re install CC again.
Keith
uninstall your current version first.
then go into the Program Files folder for CC and delete its contents
    (keep the .ini file if you have customised settings)
download the latest build from here; <a href="https://www.piriform.com/ccleaner/builds" rel="external nofollow">https://www.piriform.com/ccleaner/builds</a> (or use FileHippo for previous versions)
reboot the PC then install CC from your downloaded file.
to convert this Free version to the Pro, go to Options &gt; About and enter your license key.
mta
Thank you the Short Cut is up and running perfectly now.
Keith
no sweat. :)
