I am using the "free" version. A great product.
Today when i went to use it and selected "Run" It started to load and when it got near the end the program closed????
Help!
Als is there any way to set up a schedule for it to run automaticaly?
Thanks
Help!
Thanks
What operating system are you running?
Which build of CCleaner?
Look in CCleaner options > Advanced.
Is the option to shutdown after cleaning ticked?
Regarding a schedule, see here
http://www.piriform.com/docs/ccleaner/ccleaner-how-tos/scheduling-ccleaner
Firefox 27.0.1
Windows 7 Pro
c Cleaner v4.11.4619(64Bit)
When I "Run" it it shows it loading but when it gets to the end of the bar indicator it closes down.
Thanks for you help and interest
Please answer this question....
Yes it is so that is the answer. Many thanks.
No problem
By the way, do you remember ticking that option?
