Giveaway of the Day:
Includes DAO (gapless burning) for Audio CDs.
Thanks Tom, I've installed that with no problems.
As a free app which doesn't take up a lot of space, it was definitely worth installing to try out in my own time.
I've read (and confirmed with a peek in its folder), that it uses the "starburn.dll" by Rocket Division, apparently one of the most expensive burning suites on the planet. Whether it's the same .dll as in its illustrious relative, I've no idea, but it's got to be worth a try.
StarBurn also has a free version which I tried out last year and wasn't too impressed with it. Giveaway of the Day not all that long ago gave away the commercial version of StarBurn and if my memory serves correctly there was some reported problem with it. In my opinion the commercial version is very expensive but it still doesn't hold a candle to freeware like ImgBurn.
Point taken Big A, but if you're a downloadaholic like me, you just have to suck it and see.
I usually use Burrrn myself for audio CDs, but the price was right on this one today -- so why not? .
Same here Tom. This gives me something to talk about at the next DAA meeting.
"My name is Dennis, and I'm a compulsive downloader".
BurnAware Home Edition is a keeper in my book! I love the design and it even verifies discs after the option is ticked in the settings.
When you download this from Download Of The Day do you get a key or something to activate the full version or is the installer all you need? I don't really want to install it right now but If all I need is the installer I will save for later.
Grabbed it, thanks for the link Tom AZ.
Anthony, from the readme:
Installation
Unzip the package you`ve downloaded and run the activation program
Activate.exe which is included in the package, then run Setup.exe to
install the software.
You have to install it before the Giveaway offer for the software is over.
Terms and conditions
Please note that the software you download and install during
the Giveaway period comes with the following important limitations:
1) No free technical support
2) No free upgrades to future versions
3) Strictly non-commercial usage
Thanks. I hoped it would be a key or something that I could keep and use later.
You have to install it on the day they have it listed before the time runs out or else you're out of luck because their Activate.exe is time-limited.
Hmnn, after install the dialogue below states a years free upgrades.
Yeah I passed. I like Ashampoo and Burrrn so will stick with them.
I also don't like apps that have this time limited thing and some of them shut off after a set time etc. What are these things doing in the registry to be able to do these types of things. I don't want garbage like that. I prefer the commercial apps they give away and all you need is a key that they provide to unlock it.
Most of the Giveaway of the Day software itself isn't time-limited unless it's some Pro version of some Antivirus software and all of the commercial ones typically only come with one year of usage. It's just the Activate.exe file that is time-limited.
All those products are doing is merging the registration data into the registry which a software install watcher like Total Uninstall and ZSoft Uninstaller will confirm. They aren't doing anything dubious whatsoever.
Anyways you missed out on a rather good and elegant burning software.
Tried this out today with a 4.35Gb movie image. Took 6 minutes to burn, which is comparable with Decrypter. And it plays fine.
