Build 5.45.6611
  • CCleaner now sends a heartbeat every 12 hours which reports up-to-date usage statistics to allow for faster delivery of bug fixes and product improvements.
How I wish I hadn't read that :(
Same. No way to turn it off either....
12 minutes ago, ukheather said:
Old versions.
You may want to read my post
surely this will be the last straw for many.
seriously - just how many releases with flat out bugs or at least (very) undesirable features do Piriform think their user base will tolerate???
Does the portable version also use/send "heartbeat" reports back to CCleaner? Does using the portable version while being totally disconnected from the Internet prevent heartbeat reporting?
- Perhaps this sending of statistics to Piriform is the reason why CC (v5.45) keeps runnng after the user has closed the program ?
- I don't mind that CC sends some data/statistics to Piriform to help the developers improve the program. But then CC should ONLY do that when the user shuts down the program. I do hope that this happens INDEPENDENT of the CC monitoring feature (This feature should be fixed).
- I know that Defraggler also stores some statistics in a file called "Statistics.bin". Is this file send to Piriform as well ?
Hey Everyone,
Thanks for your feedback, please see the following thread for the latest information on this topic
- Suggestion: Add an option to allow to user to switch off that data collection to be sned.
