Problem with last version v5.58.7209 (64bit) Ccleaner delete files in my recycle bin, I uncheck this option and don't work. I prefer to delete the recycle bin manually, first time this option does not work. Thanks for your reply.
Are you using 'Easy Clean' or 'Custom Clean'?
Easy Clean uses Piriforms own set defaults, which I think includes emptying the bin.
So if you don't want it to do that the use Custom Clean, which is simply the way things used to work before EC came along.
Yes I use Custom Clean look pic. A lot of people has this problem on french and english forums discussion.
Problem solved. I did not understand that I had to stay on Custom Clean to analyze. This new Easy Clean option is really useless, it misleads many people.
Thanks
... or click "Review Junk" in Easy Clean and uncheck "Recycle Bin" before proceeding to "Clean All"
1 hour ago, Dave CCleaner said:<div class="ipsQuote_contents"> <p> ... or click "Review Junk" in Easy Clean and uncheck "Recycle Bin" before proceeding to "Clean All" </p> </div> <div> <div> <div title="Protected by Grammarly"> </div> </div> </div> </blockquote>It's not exactly obvious though for an 'Easy' feature that is supposed to be for non-technical users.
Maybe a large 'Settings' button below 'Analyze' on the EC landing page would be clearer/simpler for non-techie users to use?
(And a warning that EC does not use the ticked/unticked boxes from the Custom clean?)
