Browser Smart Cleaning options
Hi, I am using browser cleaning in the Smart Cleaning tab, but I find a problem that seems to make this function hard to use in my case. To be brief: I want CCleaner to delete everything on browser exit EXCEPT the history. Is a way to do that?
I have already unchecked browser history in CCleaner options 'Cleaner' (the first option/tab at the top in CCleaner options) for all the installed browsers, and performed a manual cleaning, just in case, but CCleaner keeps deleting everything for the browsers checked under 'browser cleaning', under Smart Cleaning.
Could someone help me to tell keep CCleaner from deleting browser history, please?
Tx!
As long as you've unchecked history in the browser you're using (second tab for 3rd party/non-microsoft browsers like chrome and firefox) it should follow those rules you set. Which browser are you using? I.e. Or edge?
Edit:
I could not recreate this in edge. With the caveat that I unchecked history in both edge and internet explorer (in case MS had merged the two).
If you want to clear everyhing in the broser except the history - I think the best option would be to do that in the browser =- IE, Edge, Chrome, Firefox or what?
I am using Edge, so it seems to be a CCleaner bug? I did not test with Firefox or Chrome.
I could not use Edge own clean-on-exit options because it would delete some cookies that I need to keep, (which CCleaner allows me to do, while deleting the rest). Really, the best option is CCleaner if only it would work for Edge as it should…
Edit: Just tested with Firefox and Chrome, CCleaner works correctly with these both. But I use Edge 99% of time because of different characteristics I prefer/need.
Edit2: Just checked and unchecked another time in CCleaner the 'History' for Edge and now it works (!?). Not really reassuring as it seems unpredictable...Should I report this in the CCleaner Bug report forum?
11 hours ago, Betty Well said:
<div class="ipsQuote_contents ipsClearfix">
		I like to use [competition software] to clean up browser traces, historical records, etc.Browser Cleanup lets you clean up junk files, cookies, and history, eliminate deceleration reasons, clear privacy traces to protect your confidential data and more. It is performed on Mac OS and Mac OS X.
As this is an official company website i've edited the competition software name out of your post, I'm sure you can understand.
On 01/08/2019 at 10:37, Betty Well said:
		I like to use [competition software] to clean up browser traces, historical records, [competition software] lets you clean up junk files, cookies, and history, eliminate deceleration reasons, clear privacy traces to protect your confidential data and more. It is performed on Mac OS and Mac OS X.
As I stated above you need to uncheck it for firefox/chrome in their respective sections on the applications (2nd) tab
