Booting Problems... Help Please!
hi people...
need some hopeful advice and help...
when i boot my machine, it'll do what it wants...
it sometimes says in the boot screen, just before the windows start, that it cannot find a boot, or something of the sort...
other times it will just start as normal... pretty strange...
i've triyed to run the computer from a linux live cd, and in the installation procedure, it just says there's no hard disc for it to be installed on...
i've also opened the computer itself, and looked inside, so i could find out if the hard disc was badly connected... but that was not the case... all cables where were they should... anyway, after that, i booted the pc again and it just runned as normal... bizarreeeee...
i do not want to rebooted now, just in case i'm not able to boot it ever again... :P
if you needed some sort of log or something else in order to detect failure, please request me so.
i no not what to do...
i forgot to say, this is not the first time this happens, it's been on all over the weekend:
booted whenever it wanted to...
bit strange acting, isn't it?
thanks for your time...
hoping to hear from you people soon!
thanks!
no problem people... all done
Thanks for the fix
