Boot time defrag causes problem?
This may not happen every time, but sometimes when you use boot time defrag, the computer will enter a "Would you like to try to start the computer normally? In Safe Mode" etc options.
I know I don't have it listed exactly as it is, but you get the picture.
Wonder what causes it to cause the computer to think it has suffered enough of a problem to need the safe mode/repair option screen?
Boot Time Defrag is at a very early stage. Using it can be risky. I would wait until Defraggler comes out of ?eta stage.
Oh, I know it can be risky.
But I try risky programs to find problems.
Then I report problems to be fixed.
If no-one reported problems, how would they get fixed?
But I do eagerly anticipate when it comes out of beta.
I have one system I keep just for testing things on, so it doesn't matter if that one crashes, heh heh!
Thanks man!
Will be keeping an eye open for the non-beta though!
The boot time defrag issue has already been stated to be fixed in the upcoming next beta. Mr. Don, maybe I'm worng but don't you already have a bott time defrag thread open :-/
I am not for sure. I have been so busy lately that I have trouble checking if my head is on straight. I am in the process of moving things, so I may not be as uber up to date on things for a few weeks while moving over, but if so, I feel sure I can update things when I get settled in.
Much kudos & thanks for the help. Will try to check later & see if it needs editing out.
You guys rock!
