first i am not a techie' but have used the android version of cc and the booster cherry picks/ suggests some apps to close, and compiles lists of other of your phones apps to close. i usually just close what is suggested in the first interface and surprise' ..not..its usually g. play and or chrome. i check he box and it doesnt seem to affect the chrome page i may have open..i guess it goes after duplicate chrome pages' or something in the background. i have only started to go to the other app list linked via this booster , the other apps listed normally in settings' of my moto x phone. i seem to remember it is realitively harmless and doesnt uninstall it. i would ask smart folks about this. just my two cents. gt, boise
I asked that back in April in the hopes of a response from Piriform....
Doesn't matter anymore as I now have my phone in 'Developer Mode' where you can set a limit on how many background processes are allowed to run at the same time.
Using this booster seems to be faulty. No matter how many apps I select to put to sleep, it will only work on 1-6 then say it's done. I then have to repeat it until every app is asleep. Anyone else have this problem?
I've never tried the booster tool, but lets start with basics. Device and Android version: Kit Kat; Marshmallow; Pie?
Thanks, like I said, I won't be much of a help here. I used booster right after your post, and I can't make much sense out of it. I was not able to replicate your bug. Sorry. Hope you get some better help.
