Bleach Bit
Anyone using it. By goodness it deleates some files wondering if it deletes to many I see some mozilla vaccume files i never seen before being scrutinized and deleted and lot of those framework files
if your not sure what We talking about
http://bleachbit.sourceforge.net/
I also use wise registry cleaner to like the optimization thing it turns of page file the lap top loads really quick
changed my AV to. from Avast to 360 total security but wont let that patch anything it seems a waste of time when windows does it
Love CCcleaner. Thanks to the guys for making it. mine has a problem at present the cleaning buttons are both greyed out not functioning
We aren't suppose to allow posts or mentioning of rival products, however what I have below could be a sort of warning with BleachBit:
I stayed with BleachBit v1.2 because newer versions are incorrectly targeting the C:\Windows folder on my XP SP3 system such as .DLL files, etc., i.e.; newer versions would break my Windows installation so I don't dare use any newer version of it.
I see no need for any other cleaner or optimization software when Pirifom has the best and safest programs being produced.
