Betfait Poker Application problem
Hello,
CCleaner 2.36.1233(old versions too), clear settings of Betfait Poker, which is not a big problem, but if you must change settings manual again, and again... it's terrible.
Thanks.
Go to "Options - Ignore" add manually add the files you want kept to the ignore list. CCleaner will no longer delete them.
*I didn't even realize CCleaner cleaned this application.
i assume you mean poker dot betfair dot com
as this is an online program, it either uses cookies flash or java.
uncheck all of those,
run ccleaner
if settings remain
check one of those off
run ccleaner
if settings remain
check another one of those off
run ccleaner
report the one that does the removal and we can help you further
