Hello Forum,
Ater running CCleaner all my recipes from my recipe binder have been deleted.Which action from CCleaner is deleteing the recipes.
Badcompany.
Hello Forum,
Badcompany.
What is the location where they are stored?
You are able to excude exclude folders using the options tab.
Hi Hazelnut,
The recipes are stored on the BBC food web-site, under recipe binder.
Bc.
That is an unusual thing to have happen! I don't really know how CCleaner can wipe out something stored on a website.
Have you first tried in options >cookies to save the BBC website where they are stored?
Perhaps also try unticking Autocomplete form history as a test also.
Just had a look on the site, my error, I thought you meant it was stored online.......
How does the Recipe Binder work?
Our binder is a Flash application that stores links to recipes on your computer. The binder enables you to easily store a list of links to your favourite recipes, so that you don’t have to search for them. You build up the binder by choosing to add recipes to your binder. The notes you add to any recipes are stored on your own computer as well.
Can I see my binder from other machines?
No. Because the data is stored locally on your own machine, you can only view it from your machine. This functionality may be introduced in the future.
Cookies are in ( Keep Cookies.) and autocomplete form is unticked by default.
Our binder is a Flash application that stores links to recipes on your computer. The binder enables you to easily store a list of links to your favourite recipes, so that you don?t have to search for them. You build up the binder by choosing to add recipes to your binder. The notes you add to any recipes are stored on your own computer as well.
Hi Hazenut,
Sorry, I thought is was stored online.So what do I change now in CCleaner.
BC.
You could try unticking Adobe flash player in applications.
Thanks Hazelnut it worked, Much appreciated.
Badcompany.
Glad you are sorted now, look forward to trying one of your recipes sometime
