Bad problems!
I used CCleaner for a first time and straight away something bad happened. I cleaned all files like instructed with the program and for to make sure everything would be fine I restarted computer, and then it happened one of my section in my hard drives (partitioned one) did not work at all. I cannot access any files or programs in there, nor I cannot do anything with it, it just says it is not active. And all this happened when I used CCleaner. ANY help from this problem???
...Any one knows help for this?! Administrators...?
shud post in one of the topics below this,admins dont look @ the hardware part as often.or maybe post in the CCleaner topics above this one
CCleaner Bug Reporting might be ur best bet
Don't know what makes you think that :)
sorry,meant that it be faster for the OP to post in one of the other places that more people visit/post @
hardware section isnt exactly the place to be ;)
Yep, I post it there allready, just first thought that because my problem is with Hardware post it here...
