I installed CCleaner.
I upgraded my computer's drives.
Now, when I call, I get the following message:
STOPCODE
DRIVER IRQ NOT LESS OR EQUAL.
The machine reboots and then reboots. Any idea ...
STOPCODE
The error you encounter Driver IRQL not less or equal, would occur when your network driver uses incorrect memory
address.
To fix the error, you can update the network driver, or you can revert the changes you made before this issue happens.
You can undo all of the changes that were made by performing a System Restore in Windows, using the following steps:
rstrui.exe > click OK
However if this doesn't work, please contact our support team at support@ccleaner.com and they will be more than happy to assist you further with the issue you are experiencing
