AVI to DVD
Hi
I have some films in AVI format, an wish to convert them to DVD(DVD+RW).What is the best program for this whether it be paid or free?
A couple of people have mentioned Nero, is it any good?
Cheers
Craig.
Nero is probably the easy way to do it, but I wouldn't say it's the best... As far as the best, I can't say. I have used Nero though.
Hi
Cheers
Craig.
Nero is excellent as a burner and will do the conversion, but somewhat slowly.
You may want to check out this post:
http://forum.CCleaner.com/index.php?s=&amp...ost&p=62531
and also search the tools and forums on Videohelp.com and Afterdawn.
Like the thread title states, there is a program literally called Avi2Dvd which is rather easy to use and is freeware.
